Add a TACACS+ Server
Add a primary and secondary TACACS+ server and specify the authentication process.
If you have a backup server configured, the AAA request goes to the backup server if the primary server is not available.
The TACACS+ server and the switch must have the same:
  • Encryption key
  • Connection mode (single connection or per-session connection. Per-session connection is the same as multi-connection mode)
  • TCP port number
    enable
    configure terminal
  2. Add a primary TACACS+ server with an encryption key:
    tacacs server host {A.B.C.D} key WORD<0–128>
  3. Optional: Configure the parameters for the primary TACACS+ server as required.
    1. Optional: Specify a single connection to maintain a constant connection between the switch and the TACACS+ daemon:
      tacacs server host {A.B.C.D} single-connection
      The TACACS+ daemon must also support this mode. If you do not configure this, the switch uses the default connection type, which is the per-session connection. Per-session is the same as multi-connection mode.
    2. Optional: Specify the TCP port to use when the switch connects to the TACACS+ daemon:
      tacacs server host {A.B.C.D} port <1–65535>
      The default port is 49.
    3. Optional: Specify the period of time (in seconds) the switch waits for a response from the TACACS+ daemon before it times out and shows an error:
      tacacs server host {A.B.C.D} timeout <10–30>
  4. Specify the IP address of the secondary TACACS+ server and specify an encryption key:
    tacacs server secondary-host {A.B.C.D} key WORD<0–128>
  5. Optional: Configure the optional parameters on the secondary TACACS+ server as required.
    1. Optional: Specify a single connection for the secondary TACACS+ server to maintain a constant connection between the switch and the TACACS+ daemon:
      tacacs server secondary-host {A.B.C.D} single-connection
      tacacs server secondary-host {A.B.C.D} port <1–65535>
      tacacs server secondary-host {A.B.C.D} timeout<10–30>
  6. Display the status of the TACACS+ configuration:
    show tacacs
  7. Optional: Delete a primary TACACS+ server:
    no tacacs server host{A.B.C.D} [single-connection]
  8. Optional: Delete a backup TACACS+ server:
    no tacacs server secondary-host{A.B.C.D} [single-connection]
  9. Optional: Configure a primary TACACS+ server or secondary TACACS+ server to the default settings:
    default tacacs server {A.B.C.D} [port][single-connection][timeout]
Configure the primary server with the IP address 192.0.2.1 and the encryption key 1dt41y. Configure the secondary server with the IP address 198.51.100.2 with the same encryption key 1dt41y. Display the configuration to ensure proper configuration.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#tacacs server host 192.0.2.1 key 1dt4ly
Switch:1(config)#tacacs server secondary-host 198.51.100.2 key 1dt4ly
Switch:1(config)#show tacacs
Global Status:
   global enable : true
   authentication enabled for : cli
   accounting enabled for : none
   authorization : disabled
   User privilege levels set for command authorization : None
Server:
	              create :
Prio      Status  Key         Port  IP address      Timeout Single Source          SourceEnabled
Primary   Conn    ******     49    192.0.2.1       10      false  0.0.0.0         false
Backup    NotConn ******     49    198.51.100.2    10      false  0.0.0.0         false
Switch:1(config)#no tacacs server host 192.0.2.1
Switch:1(config)#no tacacs server secondary-host 198.51.100.2
The following table defines parameters for the tacacs server host and the tacacs server secondary-host commands.
Variable
Value
{A.B.C.D}
Specifies the IP address of the TACACS+ server you want to add.
Only IPv4 addresses are valid.
key WORD <0-128>
Configures the authentication and encryption key for all TACACS+ communications between the device and the TACACS+ server. If the key length is zero, that indicates no encryption is used.
You must configure the same encryption key for the TACACS+ server and the switch.
port <1-65535>
Configures the TCP port, on which the client establishes a connection to the server. A value of 0 indicates the system specified default value is used. The default is 49.
You must configure the same TCP port for the TACACS+ server and the switch.
single-connection
Specifies if the TCP connection between the device and the TACACS+ server is a single connection. If you specify the single connection parameter, the connection between the switch and the TACACS+ daemon remains open, which is more efficient because it allows the daemon to handle a higher number of TACACS+ operations. The single-connection is torn down if TACACS+ is disabled due to inactivity.
If you do not configure this, the switch uses the default connection type, which is the multi-connection. With the multi-connection, the connection opens and closes each time the switch and TACACS+ daemon communicate.
Note:
You must configure the same connection mode for the TACACS+ server and the switch.
To enable single-connection, the TACACS+ daemon has to support this mode as well.
timeout <10-30>
Configures the maximum time, in seconds, to wait for this TACACS+ server to reply before it times out. The default value is 10 seconds.
